CRF 2010 kickstart lever on 2009 (?)
So, as we all know <2009 CRF250Rs can be a bitch to start, I have a R9 myself and it can be a pain.. I have the bike for awhile so I know some tricks, but it still takes me some time to get it started sometimes...
The kickstart lever on the <2010 CRFs seem much wider and bigger that may also make starting a easier task..
I know where to get a used lever for around ~$40, and I am sure it will fit right on, thats not an issue..
Has anyone done this mod? Is it worth it? Does it actually change much?
Thanks in advance !
oh and I did a little preview with the new lever below :::
I have had plenty of honda 250fs all with the same problem of starting. my last one was a 2010 and was much easier to start than the carbuerated bikes. as far as the start lever mod im not so sure that will help but 40 bucks why not. as far as tricks for the 09 i use to drain old fuel from the carb, then give it about 3 twists of throttle and hot start when cold. on cold days id leave a blanket over the bike with a heater under it literally just warming up the bike and itd start right up.
