ct-90 help
hey all i have a buddys dead ct-90 here at the house and it has no spark. im thinking its the coil but is there any whay to test it and be sure? also how do i test the rectifier? if the rectifier is bad will that cause no spark? how bout the condensor can i test that?
Replace points and condensor with new set, CT90 and 110 I belive they work off Magneto Stator which dosen't need a battery for spark but I could be wrong as I don't recall off hand on thoses model Honda.
The Rectifier is just use converts AC current to DC current for running the Head Ligth and other ligths and changing the Battery.
If have a 6V battery charger you could try hook it up to see if get any spark that way.
