"older" kx100 with new carb?
Hi, i have a 96 kx100. I was thinking about getting a 28mm carbon from a newer model kx100 rather than the stock 26mm. My question is will this work? If anyone has done this swap is there any noticeable power difference. Any information would be great thanks
A larger carb will generally provide more top end at the expense of low end grunt and throttle response. May or may not be worth it, depending on how you ride. Jetting may also be a challenge.
