---Lower Link Length Chart---
Honda calls the link a "Rod". I don't know the length of the XR400 link but I have the lengths of 4 other other candidate links:
84-85 XR200R/250R 52470-KF0-010 84.1mm
86-88 XR200R 52470-KT0-670 81.6mm
86-95 XR250R 52470-KN5-000 84.5mm
96-04 XR250R 52470-KCZ-000 79.9mm
A longer link will lower the bike.
The longer link lowers the bike and lowers the spring stiffness.
A shorter link will raises the bike and increases the spring stiffness.
The stiffness change is caused by the change of the ratio rate.
The change in length is about 3x. 4mm = about a 12mm change.
So far here is a part numbers to application list and which one are missing. :smashpc:
84-85 XR200R 52470-KF0-010 84.1mm
84-85 XR250R
83-84 XR350R
83-84 XR500R
85-87 XL250R
84-85 XL350R
83-87 XL600R
88-00 XR600R
93-00 XR650L
85 XR350R
85 XR600R
96-04 XR400R 52475-KCY-670 Length needed
86-87 XR600R 52470-MK2-770 Length needed
01-03 XR650L 52479-KZ1-305 Length needed
04-09 XR650L 52475-MY6-A40 Length needed
chuck4788, Thanks for your accurate measurements. 👍
If any one can help complete the list post up :busted:
Aftermarket lowering link lengths would be great too. 🤣
Thanks. 🤣
devol was around 3 5/16, ill have a more accurate number when i pull it in a few days, xr650l 2007
Edited by skirecs
Which bike ?
The kouba link for the XR650R is about 4-1/2" or 114.3mm. (Not exact, but close)
84-85 XR250R
83-84 XR350R
83-84 XR500R
85-87 XL250R
84-85 XL350R
83-87 XL600R
88-00 XR600R
93-00 XR650L
85 XR350R
85 XR600R
Thanks. 🤣
Late to the party that's me, well almost with a new to me (2-16) 85 XL350R project "save me" bike. Part of its life in the dirt by the PO without an air filter. Have plans of lowering the suspension for street bike duty with street tyres plus adding an 84 XR engine from carbs to muffler to it.
85 XL350R link measured 84.40 mm long, CL to CL, call it a 84-85 XR200 of 84.1 or a 86-88 XR200 (81.6 mm) as posted above.
Purchased used 650L KoubaLink lowering link, I pressed in new bearings, end caps and "O" rings which measured 95.25 mm CL to CL long.
Told by KoubaLink "the 650L link will not fit a 85 XL 350R", wrong it will once I milled out .008" deeper into the radius of each side of the "yoke" towards the "yoke" bottom pocket. The link end caps now slide in deep enough for bolt alignment. before the caps begin to pinch the "yoke" radius.
Stupid question, how much will this lowering link lower the XL 350R's rear suspension, talking 10.80 mm longer link?????? Raise the fork tubes up the triple clamps the same amount.
Carl.....~~=o&o>......
can't seem to find the devol lowering link length anywhere. I know stock is 135mm, pro circuit is 136mm.
finding a big good egg on the devol. anyone know the devol lowering link length for a 2012 kx450f
