Weight of Dunlop 110/100-18 Tire?
I believe there a bigger difference than a few ounces, especially with the 18" rear tires.
For my WR250F, with a 1.85 rim, I have tried:
D756 100/100-18 = 11.0 lb
D952 110/90-18 = 11.5 lb
MX51 110/90-18 = 12.0 lb
MX71 110/90-18 = 14.5 lb
For my CRF450X, with a 2.15 rim, I have tried:
MX51 110/100-18 = 13.5 lb
Maxxis Desert IT 110/100-18 = 14.5 lb
My resolution is low, +/- 0.5 lb with the scale I'm using. So, the differences may be slightly less. Also, I have seen posts where folks in motorcycle shops have measured their stock of same type of tires and found variability of 0.5 - 1.0 lb.
The original tire on the CRF450X was a D756 110/100-18. It was old, worn, and the rubber was a little dried out and brittle when I removed it. It weighed 11.5 lbs in it's used state. So, maybe it weighed 1 or 2 lb more when new? Just curious.
I'm not saying that I can absolutely tell the difference in 1 to 2 lb of unsprung weight or rotational inertia, but I do like to be aware of whether I'm adding or removing weight and understand the differences in tire handling and durability when I make my tire choices.👍:ride:
