Primary crank gear seized
You mean the nut is stuck? Use some heat in the form of a small propane torch, right on the nut. This is in case it is Loctited on, the heat melts it.
Are you sure it's not a left handed nut?
What he said. I know my KTM smoker cranks is "reverse" threaded. If you have the impact wrench set for the proper thread, it should loosen it right up.
