FCR 41mm on XR650R
Had a KTM 525sx die on me. Carb is new Generation III FCR 41mm that was just massaged by KTM engine guru.
I am thinking about putting it on an XR650R. Saw a Sudco Kit for $750? but can't figure out what would be in that kit to make it cost so much.
I haven't calipered the air boots, but they look close enough to make it work.
Yes on the rejet. Just wondering if there is anything else that would keep it from working as a bolt-on?
carb model/year 2008 Gen III (450 SXF type)
Bore size 41
Check Vacuum Release plate OK
Set slide height .052"
Oversize the AC pump spray Nozzle .018"
Check/test the AC pump check valves OK
Check/test the AC pump start OK
Check/test/Adjust/limit the pump duration 1 sec + or -
Shim 2mm
Check idle mixture screw tip ok
Install aftermarket mixture screw has
Check idle mixture screw O-ring, spring replaced
Check float level/mark on bowl at top of FCR boss
Pilot Jet 45
Clip position OBDVR retapered marked red 1
Jet Needle OBDVR retapered marked red
Main jet 180
