need some help finding replacement parts
just picked up a used xr50 with a Takegawa 88 kit on it, and I'm just going through it and replacing some broken parts.
I believe I have the Keihin PC18 carb on it, and I need a new cap for it, or really just the threaded brass piece that goes into the carb cap. Where can I find this? Will I be able to find an extended throttle cable that will work with this carb?
any links would be greatly appreciated.
Thanks Yall
It's called a cable adjuster, the Keihin part number for it is W9581-59250, the SUDCO number for it is 018-005 and SUDCO sells it for $1.93
You can contact SUDCO HERE
