DRZ 400E jetting question
Hi all. I have a Australian model DRZ 400e with MRD SSW exhaust and have removed the snorkel from the air box. I was just wondering if changing from the stock jetting is necessary and if so how much of a difference will it make. I have been told to go from a 165 main jet to a 160.
Max
Just change the needle set up and the main jet...The other jet sizes should be stock..
160 main jet
200 main air jet
100 pilot air jet
EMN needle clip 3 or stock DXP needle clip 5
45 pilot jet
2.25 turns fuel screw
Remove the coast enrichener.https://thumpertalk.com/forum/showthread.php?t=726110&highlight=coast+enrichener+removal
Do the Eddie Mod..https://thumpertalk.com/forum/showthread.php?t=890079&highlight=eddie+mod
To make easier pilot circuit tuning I recommend get a R&D Flex Jet remote fuel screw...You will need to slightly enlarge the fuel screw orifice on the bowl.,(with a drill) to install the Flex Jet.http://api.viglink.com/api/click?format=go&drKey=294&loc=http%3A%2F%2Fwww.thumpertalk.com%2Fforum%2Fshowthread.php%3Fp%3D10626773%23post10626773&v=1&libid=1314872488816&out=http%3A%2F%2Fshop.thumpertalk.com%2Fcatalogs%2FParts_Unlimited_Offroad_2009%2Fdefault.asp%3Fp%3D817&ref=http%3A%2F%2Fwww.thumpertalk.com%2Fforum%2Fforumdisplay.php%3Ff%3D25&title=DRZ400e%20Jetting%20-%20ThumperTalk&txt=http%3A%2F%2Fshop.thumpertalk.com%2Fcatalogs...ault.asp%3Fp%3D817&jsonp=vglnk_jsonp_13148725794081
just change the needle set up and the main jet...the other jet sizes should be stock..
160 main jet
200 main air jet
100 pilot air jet
emn needle clip 3 or stock dxp needle clip 5
45 pilot jet
remove the coast enrichener.https://thumpertalk.com/forum/showthread.php?t=726110&highlight=coast+enrichener+removal
do the eddie mod..https://thumpertalk.com/forum/showthread.php?t=890079&highlight=eddie+mod
to make easier pilot circuit tuning i recommend get a r&d flex jet remote fuel screw...you will need to slightly enlarge the fuel screw orifice on the bowl.,(with a drill) to install the flex jet.http://api.viglink.com/api/click?format=go&drkey=294&loc=http%3a%2f%2fwww.thumpertalk.com%2fforum%2fshowthread.php%3fp%3d10626773%23post10626773&v=1&libid=1314872488816&out=http%3a%2f%2fshop.thumpertalk.com%2fcatalogs%2fparts_unlimited_offroad_2009%2fdefault.asp%3fp%3d817&ref=http%3a%2f%2fwww.thumpertalk.com%2fforum%2fforumdisplay.php%3ff%3d25&title=drz400e%20jetting%20-%20thumpertalk&txt=http%3a%2f%2fshop.thumpertalk.com%2fcatalogs...ault.asp%3fp%3d817&jsonp=vglnk_jsonp_13148725794081
+ 1 ...
Does the Aussie E model have the coast enrichener on the OEM FCR like the US E model? Just curious if the CE needs to be removed/capped off with the 100 paj for the OP?
I have the same combo and jetting with EMN needle, capped CE, Eddie mod and she runs soo awesome!
