wierd chain slap???
My buddy had a cheap chain on is '04 and it crapped out on a trip so we put a DID o-ring (not the gold one) on it that we found at nearby store. He has the spacer on drive sprocket. Anyway now the thing slaps like crazy even while cruising. Everything appears to be lined up and adjusted well...even a little tight maybe. Any ideas I'm a little confused....and it drives me nuts following him???
added: Just put tusk axle blocks on it....I assume the marks are true side to side but who knows.
If its adjusted properly it shouldn't slap very much. Maybe the rollers are worn or missing. My buddy always has a lose chain and the slap drives me nuts. Makes me think my engine is comming apart.
I've heard you will always get some slap.. My D.I.D x-ring chain has slapped so did the D.I.D. x-ring before it.
did you change the size of either the front or rear sprocket, and if so.. did you happen to go bigger at either end?
