08 250sxf knocking, need advice..
Bought the bike knowing it had a knock or (tick) as I originally thought. Valves all within spec, the bike probably has around 10-15 hours on it. Replaced cam chain tensioner to dirt tricks model but no difference in motor noise.
Now I am sitting with the cases split and crank out of the motor but I just don't see any wear or bad bearings. Piston and cylinder look brand new with excellent compression. Crank has little side to side play but no up and down. Got a second opinion at a local shop and was suggested to replace crank+piston as set because of possible uneven wear. I'm comfortable doing this but just looking for advice. The knock was loud enough that I definitely expected something visible to be bad, but I just don't see/feel it.
Can post pics or measurements if that would help anyone, thanks.
I have no thots other than to try calling one of the good builders like Travis at Thumper racing or Dave Hopkins and see what they have to say about it. You hAVE DONE THE THINGS i WOULD HAVE DONE ALREADY.
