1996 trx 200d
The ATV was running fine, until one day it made a noise with our daughter, shut off, and hasn't started since. We appear to have an intermittent or abnormal spark. When we hit the start button we get a few sparks. When we let off the start button we get spark again. We have trouble shooted according to the owners manual. The last test on the list was to measure the pulse generator coil resistance between the Blue/yellow wire terminal(connects to pulse generator coil) and ground. The standard ohm should have been 290-360. The wire would not ohm at all. We replaced the pulse generator coil and we still have the same problem. We replaced the wire and it would ohm until we grounded. The CDI box has been replaced and the ignition coil. Replacing these parts did not affect the problem at all. Any suggestions will be greatly appreciated.
