04 wont start
this bike wont start all it does is blow a puff of yellow flame . checked timing ,shims , clearance ,carb all is good now what
did you check the sighting holes on the cams when you retimed it? the gear and lobes have holes through them so you need to make sure they all line up as the 04 is shocking for the cam gear spinning on the cam... if it has spun get it pressed off use a dowel through all the holes to line them back up press the gear back on and put a little tack on it so it doesnt move again.... if its not that the other thing on the 04's is the cdi there was a recall but not all of them got done... for me in NZ this was the best option
http://www.electrosport.com/dirt-bikes/kawasaki/kx250f-04/suzuki-dirt-bike-cdi-pe-c-ms-k250-a.html
i just went through all of this with my 04... hope ya get it sorted 👍
