200 XC rear brake lever stop jacked up
OK, so have a 2006 KTM 200 XC. Having an issue with the rear brake foot lever. The stop keeps bending out the threaded bolt hole for the stop. Why is the bolt hole split? Gone through 2 levers now. Both times loctite the stop. Is there better 3rd party replacement over the OEM? It is an expensive part and the split bolt hole design makes no sense to me.
i had a similar problem. Solved it by putting nuts on both sides of the hole and tightening them up.
