2011 yoshi pipe on a 2009 crf450r
Hi does anybody know if you can make a rear bracket so the 2011 exhaust will fit onto the 09.
i think the mid pipe mount is in the same place
why? just buy the 09-10 pipe... it's cheaper, than they 11-12 anyways
but to answer your ?, I'm not sure.
Yes you can!I have made a bracket up to fit an 09 pipe on an 11
just connecting the two mounting points will not support the weight of the muffler on hard landings etc. and will cause premature failure of the mid mount
Im sure it works fine , but if you want to see how good connecting the mounts holds the weight of the muffler , just take the mid mount bolt out and go do some jumps and whoops and see if the muffler is still up where it belongs , as it is , the mid mount is taking extra pressure on every bump , if you put enough hrs on it you will find the weak link
