2002 cr250 crank seal leak
well i had suspicion i had an air leak. i had a surging idle when i stopped after bieng in high rpm range. so i took my mag cover off and the bottom had a buncha gas smelling oily stuff. i would assume the seal is gone. could this be responseable for my long reving hanging idle. thanks
yep been there done that on my af500..... pull off flywheel/stator plate, pull out seal, clean area, make sure flyewheel is bure free, tap new seal in, oil seal and slide flywheel in place... really only bout a 30min job if ya got the right tools...
