Spring Rate & SAG Dilema
if static sag needs to be 42mm, but I'm running 47mm, what rate spring is required coming off a 5.8kg?
Edited by rickk
cool thanks...I was leaning 5.6 or 5.7 but didn't know if the 5.7 would make enough of a difference.
Honestly, if you're changing springs to get 5mm static sag then I'd probably save my money and put it else where.
you mean $80?...Where would I put that?
I have little choice. I'm way out on my race/static sag and HSC/LSC to make it work so I pretty much need to do something, even though technically, I'm the right weight for the 5.8kg.
What end are you wanting to run 42mm ? Sounds like the front. Rear should be less sag unless you have an older KTM with PDS shock with topout spring.
