Odd spark plug color.
I was recently fouling plugs within a few minutes after starting my 01 YZ125 so I started making some air screw adjustments this weekend. At about 2 turns out the bike was pulling pretty hard thru out the band with a barely noticeable bog when twisting the throttle and, didn't foul. I pulled the plug and this is what it looked like (sorry, no pics). Looking straight down into the bottom of the plug imagine looking at a circle then draw a line thru the middle. Exactly 1 half of the plug was dry and black, the other half was dry and white. In other words, half of the plug had a lean color, the other half rich. Anyone ever see that color pattern before or have any ideas what would cause it?
sounds like you need to give it a good 30 hard ride to see what the plug looks like. If you are getting good throttle response with a little bog off bottom then more than likely your about spot on.
bet you are looking at the difference of the exhaust side and intake side
I had thought about the color difference being caused by intake and exhaust side but wasn't sure if that was possible. I'm rather inexperienced with the 2 strokes. Anyway, I put in a new plug and rode for about 30 minutes in the woods. Pulled the plug and it was a chocolate color, thought I could live with that. Let it set for about 30 minutes, started it and warmed for a few minutes then rode about 100 feet from the shop and it fouled.
