I burn 2-4 oz after a few races
just like the title says, or maybe 2 practices and 2 races and I'm at the very bottom (underside) of the dipstick.
is it cause I'm not using synthetic oil? I'm using Honda GN4. Thanks
How many ours on the engine since the last rebuild? Could be valve seals, piston rings, or the oil could be migrating to the trans side.
How often are you changing your oil? My son puts an average of 3 hrs on a practice day and 1-2 hrs on a race day so I typically change the oil after a practice/race day or every 5hrs. If you ride about the same you are doing almost 10hrs on same oil.
Alain
ok sorry guys I should have been more clear. It was a fresh top end build and the first run was in April. I only practice on the mornings of race days. I attended about 12 races so far this season, but I have seen this since the first event back in april
Now I will Really Elaborate: I found that I was loosing motor oil into the tranny side and repalced the seals inside the case about 3 race days ago - now my tranny is Not overfull after practice mornings and the end of the race day.
But I still use the same non-synthetic Honda racing oil GN4, and I'm still at the bottom of the dipstick 3/4 of the way through the day.
I change both oils after every other event, but alternate engine sides, 1 event tranny and leave the motor oil, and the next event change the motor oil and leave the tranny
If no one comes up with a good reason I guess I'll have to switch to synthetic and see...
ok so I just checked my tranny level using the fill hole screw. it dribbled out for 2 minutes so I guess that could be what I'm seeing in loss on the engine side. So if this is true the seals I put in the cases are only working 90% or so. I don't know, I haven't heard of Anyone else battling this issue before...
thing is, when I fill the tranny area, I take the check fill hole screw out and wait for it to barely come out. So when I'm at the track and I take the screw out to check, the oil is HOT, so when I see it come out at a slow pace, I figure it's expanded from the heat and everything is good. Pretty annoying
No need to run synthetics, petroleum based 10w-40 is all you need. Check your spark plug and I would pull the head and look at the valves. Most likely your passing it from the top end.
thanks. Maybe you could school me on how to know if it's getting past the valves by doing a visual inspection? The plug looks beautiful/tan
I would guess your valves would show above average carbon deposits. I would call a good motor guy that has 100 times more knowledge than me and get the skinny of where and what to look for. You can pm me and I'll give you my motor builders info.
thanks bud. I have a really good guy, he did the entire head in the spring. I just have a disease for doing things the hard way and learning myself...
well, yesterday was a race day and the saga continues. the trany fluid pretty much stayed where I left it, so I guess the seals are ok. But This time, after 3 practice sessions, the motor oil wasn't even on the dipstick! changed the oil before I left my house
so I'll be doing new nikasil, piston, rings, valve guides and guide seals, among other goodies
Are blow any white smoke out from exhaust?.
If not then more like you did fix your problem on the crank
Give a bit more time over fill
it gives a little puff of smoke when it's in neutral and I rev it, every time, not sure bout when I'm riding it.
After the rebuild I put a new vent kit on the carbs, just cause I wanted red tubing 👍
the valve cover vent hose ended up getting kinked AND I put the case breather hose in the catch can. With this config lol the catch can was filling with oil and I was blowing A Lot of smoke out the exhaust. I fixed it after 3-5 minutes of riding like that.
does anyone think that could cause the rings to never seat correctly?
That normal if it just puff black smoke
That shouldn't have any thing to do with it
It possable you could have burn up the valve seal
Have you check the catch can after each ride if fill back up then that blowby and it would have to do with your below quote
That Possable or some else you never know in tell take the head off and cylinder and look things over really well
If the crankcase breather was kinked the most damage I would guess would be blowing the crank seals. Which would just fill the trans up like you saw the first time. If its puffing smoke in the exhaust (bluish white, not black) then it could be rings or valve seals...
My son has a 08 150rb and after about 3 hours his oil is off the dip stick from full. Only blue smoke is sometimes if he revs it high. At this point we just keep oil in the tool box.
Thanks everyone. Nov 5th is my last race. Right after that I'll tear it down and let ya know what I find. it's all getting worked:banana:
Sorry this might be just a dumb question but are you checking the oil with the bike vertical or on the stand? It should be vertical not on the side stand.
The reason I ask, is I had a friend that was getting a lot of oil in a sport bike air box and he was over filling because he was checking it on his side stand. once he started to check it correctly he had zero issues.
I measure my oil at oil changes and its withing a once of when I filled it. I always put in the same amount and its prefect on the dipstick. Its like about 20oz on one side and 19oz on the other. Or 19oz and 18oz I have it written down in the garage and use a ratio right to measure.
yes it's always been straight, thanks. Top end is in my hand and it looks real real nice (to me). When my engine guys gets his hands on it and inspects the valve seats and faces I hope he has something to say except 'it looks great'....
