Shift lever hitting frame issue
Hello,
My 2009 200exc's shift lever will hit the bikes frame if I try and adjust it to sit slightly lower or level with the footpeg, making it impossible to shift down.
I was wondering if anyone else might have a solution to this problem? I was thinking a quick fix would be to attach something to the bottom of it, but are there any better ways to fix this? Is it possible to simply bend the shifter or will that compromise its strength?
I can upload a pic if that would help
Thanks
I put my shifter on a bench grinder, grinding a notch it. IDK what changed because i didn't have the issue with my 05.
