XR100R Stock Sprocket Tooth Count?
Does anyone know what the stock sprocket tooth count would be for the front and rear sprocket of a 2002 XR100R? Also if i kept the front sprocket stock, do I raise or lower the rear sprocket 2 teeth for added torque?
HERE you go...
For more low-end pull, you can go down one tooth on the front sprocket, it is the same as going up two teeth on the rear sprocket.
13/50 - 3.84 to 1
14/52 - 4.00 to 1
Easier to change the front sprocket, BTW...
HERE you go...
13/50 - 3.84 to 1
14/52 - 4.00 to 1
Ok so according to that JT sprocket link you posted, stock front sprocket is 14 tooth and rear is 50 tooth? Just really want to make sure of that. And say if I want to keep the stock sized front and rear sprockets, what size chain should I run? I want to run the Renthal R1 428 chain, but how many links do i need for the stock set up? Web sites list 120,130, and 140 links for that specific chain.
That's correct, the stock gearing is 14/50 and it takes 118 links, so a 120 link chain will work for you.
