tubeless tires?
Anyone have any experiance with tubless tires such as the Nuetech TUbliss tire system or anything else. I dont know anyone that has ever used them and i am just carious about them.
I have three Tubliss systems. Two for Dunlop 803 18" tires and one for a 21" tube type knobby. They require a bit different mounting technique but allow you to run lower tire pressures for more traction, and the tire bead stay tight against the rim
I run low pressures and after a year the 21" tube knobby started leaking air thru the casing, a brush coat of Slime on the inside fixed that. I now apply a brush coat of Slime to all sealing surface when mounting.
I have the Tu-bliss system and think they are great. It's been discussed on here many times. Do the search.
