1999 kx125 clutch noise
I rebuilt a 99 kx 125 two years ago, New crank, crank bearings, seals, top end. Ran like a bat outta hell. Over the winter I put new clutch discs & plates and filed the shallow grooves on the basket. No problems,, still runs strong but it is making a slight noise when the clutch lever is not pulled in. Makes the noise in neutral. Noise goes away if you pull in the clutch. Its a EBC Dirt Racer clutch and I,m using a Honda gear oil. The noise wasnt there until after a few hours of ride time.
I have the same bike, same issue. Smooth as silk with the clutch in, let it out and you can feel the bike change tone, and vibration. I never thought it was a big deal.
i have the same problem on my 94 250 and im pretty sure its one of the bearings either the one inside the pressure plate or another one. i was told they almost never stop working they just get a little noisy. in a few weeks im going to be redoing the entire clutch and if the noise goes away il post about it
