Front wheel issues once again -_-
after bearing issues I finally got them sorted out and replaced. After everything was installed I mounted the wheel back up only to find that it still had wobble. The spacer on the opposite side of the brake caliper wasn't matching up to the fork. It was the exact width of a bearing. So what could cause this space? I made sure the forks were straight and everything was installed correctly.
The nonbrake side fork floats to center. It shouldn't press against the spacer. The flange on the axle should press against the spacer.
Is this what you are seeing?
yes... and no. i suspected that but there was still wobble in the wheel. so i could race this weekend i sat a bearing on the axle on that side to stop the wobbling 👍 i probably shouldn't have and i talked myself out of it several times but it worked and didn't tweak anything out of line. plus i couldnt miss the first race of the season lol.
he is right, the aacxle doesnt look like it is in all the way, but it is, it leaves a gap on the non brake side. Wheel wobble may be a bent wheel or loose spokes.
never heard of a bent wheel? Would it be the hub that is bent or the rim? Spokes are fine. I check everything before every race. I treat her real good, I'm just a broke-*ss college kid. I'll post a pic up later
