1997 RM125/250 49mm Fork Manual
Mods: I realize this would fit in the suspension forum though I am looking for Suzuki-only info. Thanks.
Fellas: I want to toss the fish oil in my forks and replace with new oil. Does anyone have the manual section on these forks? I'd sure like a copy before I do a blind flush and new oil. Thanks!
I redid my showas on my 96 with my Clymer manual, and it detailed everything out very well.👍
They're almost exactly the same as modern showa twin chamber forks so you can look up video on those. The only difference is you need a spanner to hold the bottom plate while unthreading the rebound adjuster. If this is a trail bike you may also want to start a lot lower than the recommended oil level and work your way up.
Yes, trail riding. I've read 200-210mm of oil level. I take it that is with the springs out. What brand/weight of oil should I use? The stock should be fine for my weight.
What do I use to flush out after draining? Is kerosine or diesel ok? Seems like some residual of either would get left behind. I'm considering a total disassemble for later after riding on them for a while once I figure out what (valving) I want to change or leave it to a tuner.
Found an RM125 service manual on that auction site, and will go ahead and buy/use it.
Oil volume not level for cartridge forks. Start with 210 and go up in 10cc increments until your happy. Use whatever 5w good brand you have at your local dealership. For cleaning use contact cleaner or brake cleaner if you can't find any locally. For valving, just message me whenever you want some changes and I can try to help.
Also, you need to check the stock springs for negative preload and use a spacer to get to 0 to +3mm if need be. To check just unscrew the slider and measure the gap between the spring and the spring seat. They changed the design in 98 to fix this problem. Just do it before you dissemble everything the first time.
After looking all over the place, and to the satisfaction of those who got nothing else to say but "buy a service manual",I did just for only that reason, $12 from Ebay . Tired of wasting my time with opinions. Manual just came in the mail today. A greasy, fingerprinted original, from Suzuki.  On page 15-3 it says fill the outers with 540 ml. for rebuild, 505 ml for oil change. 200 ml from the top with springs out.  The inner capacity is approx. 155 ml. Basically fill, and bleed them.  Racetech says 450 ml for the outers. BTW, they went on my 03' KTM 200 MXC. They are not plush with stock valving, as I thought I would try them first. BUT- they are a massive upgrade. They stay up in the stroke, and despite being a little stiff, follow the ground, even on the small stuff, and have given the bike a whole new ability to handle the big stuff. They are better forks than my 03' YZ250, which I had revalved by a professional twice. They are also better than the 4cs forks on my 16' KTM 350 350 XC. I may revalve RM forks later, after I put some time on them, and bring the sucky rear up to spec. Don't want to hear about this being an old thread.
