2012 crf450r suspension tips
Just bought a 2012 crf450r and wondered what a good starting point would be for suspension set up. I am 5 11 175lbs, (gear on) fairly agressive( hot into corners, not afraid to jump). I ride often, and race occasionally in the over 40 class.
found a bunch of good info on that one. try 105mm of rider sag. start with the clickers on the stock positions, and tune from there. all the indications are the linkage upgrade was positive in the handling department. also, they increased the size of the upper tube to increase ridgidity/stability in the front end. looks as if the bike will be well received, but time will tell on that one.
