inner front fork tube
i recently had my forks rebuilt and it was leaking on the first ride...so i took it apart and the plastic peice on the inner fork tube that covers part of the inner dampening spring was broke...how do you think this happened and also can i buy just that peice....i have looked on a couple diagrams and it dont show it.
Check out the suspension forum. If I'm thinking the same part as you described, this part breaks fairly often. The trick is to be able to find that individual part and not have to buy the whole setup. I know this component is available as i had this break on my 07 and had it replaced for around $50. Check out that forum and see what you find.
