Is Applied Racing Crankcase Vent Kit worth it?
I am getting ready to check the valves on my 2006 CRF450R and read somewhere that I should also instal an Applied Racing Crankcase Vent Kit. It is only $20.00 and I am not exactly sure what it does, is this a worthwhile purchase or should I skip it?
Thanks,
Nick
That kit isnt expensive for a reason. Nobody needs it. The factory vents the blow by out of the valve cover back into the intake because its politically correct to do so. You can do the same thing yourself with stuff from Autozone. But you wouldnt have the trick little anodized breather either.
If youve got a Jackson burning a hole in your pocket, why not? Applied offers the breather 15 bucks if you just wanted that part too.
