2001 CR clutch issue
For some reason, when I pull in the clutch and put it in gear, it acts like its already in gear. I haven't checked anything yet, when it warms up it does better but even when the cable is adjusted all the way out it still will stall out unless I give it a little gas when I put it in gear. then it grabs when I let it almost all the way out???
If your cable is adjusted correctly, then you have either, a broken clutch plate, or grooves in your basket or hub. Pull lay the bike on its side and pull the clutch cover, and inspect.
