01 300 rear shock question
i just replaced shock bearings on my 01 300mxc.when i put it back together there is little play on bottom bearing where the bolt goes through. swingarm is able to move up and down a bit. is this normal? i used piviot works kit.👍
Something is not right... there shouldn't be any play in the heim joint.
there is no play on actual bearing.just where bolt goes through spacer. i just looked and the oem one is the same.if you put your bike on stand does you swing arm move at all?thanks for the input:thumbsup:
