kxf 450 revalved
hi ,i ve made this stack for a 450 09 kawa
drill float piston,400cc oil maxima 5
ics spring spacer 2mm
base 32x0.10x2
26x0.10
32x0.10x11
30x0.10
28
26
24
22
20
18x0.10
16x0.25x3
mid
20x0.10x6
18x0.10
16x0.10
14x0.10
12x0.10
11x0.20
11x0.30
17x0.30x2
10x0.10 flot 0.10 less than stk
reb
20x0.10x3
13x0.10
20x0.10x2
18x0.10
16x0.10
14x0.10
12x0.15
the shock drill 2.5mm piston hole
44x0.25
44x0.20x8
36x0.15
44x0.20x2
42x0.25
40x0.25
38x0.25
36
34
32
30
28
26
24
22x0.25
tolto base 20
rebound
40x0.20x4
36x0.15
40x0.20x2
40x0.25
38x0.30
36x0.30
34x0.30
32
30
28
26x0.30
tolto base 24
maxima 7 oil 160 psi
i try the bike work good the rider like a lot
it s stiff but for a fast rider work good
How would that stack work for a fast A rider 230lbs w/o gear. Fast rocky conditions. Hard hitting g-outs?
the rider of the stack is 170 lbs .the bike use stk spring and and have no bottoming on g-outs .the bike don t collapse under braking in downhill.work high on fast hard repeated bump but give a feedback on bar .have good traction on the hole in acceleration ,the rear not subside .in europe the track are full pierced in the corner exit.fork oil is maxima 7 not 5
for your weight the spring is not done and the stack is softner,if you change the spring the rebound is too fast.but with a little change i think work good for you
