spark plug tool
I need a spark plug tool for a 1998 Suzuki DR350 dirt model with the smaller plug. Who has the cheapest one available?
:worthy::worthy:🤣:ride::ride:
:bonk::bonk::bonk::bonk:
:worthy::worthy::worthy::worthy:
👍:ride::worthy:
I have no idea who has them the cheapest online but you may want to check your local power equipment/chain saw shops.
Should be 18mm
By the time you pay shipping you're probably better off buying it local.
dirt models different from street?
my 99 dr350sex uses a 5/8 plug socket
I'm pretty sure the dirt model takes an NGK D8EA which is 18mm
The S models take an NGK DPR9EA-9 which is 18mm
I'm not sure what plug the '99 SE takes 👍
It usaes a 5/8 socket, I got mine form dennis Kirk, I think it was $10, but I got the 6" and it was too long. I think a 4" would be fine. It is basically a cheap socket and you use a wrench to turn it. I drilled a hole to use a screwdriver
