Repacking a FMF Turbine Core 2.....
Well I pulled the screws out and pulled the silencer apart and removed the old pack. However looking at the cone end of the silencer there is a lot of carbon and gunk built up in it. So do I just drill out all the other rivets and pull this part out?
Or is there another way to clean it out without going through that hassle? I assume if there wasn't then FMF would have put screws on that end too.
I've done it two ways. Easiest is when I had a sandblaster available to me, it got a lot of it very clean with minimal work.
I've also just let it soak in gas. Not perfect, but it does take some of the residue off.
I wouldn't mess with the rivets and instead just some elbow grease with a wire brush.
