Clutch Cover - 2008 VS 2011
Somehow I put a hole in my clutch cover with my rear brake. I must have laid the bike over or had a rock hit the rear brake lever and that punched a hole into the case.
1) Is the case made out of aluminum or magnesium?
We plan on getting a new case and keeping this one for emergency replacement but would need a way to seal this crack/hole. If it's magnesium, I suppose JB wield would work fine.
2) Is there a difference in the 2011 case and 2008 case? Looking at KTMWorld, the 2011 is 40 bucks and the 2008 is 85 bucks! What's the deal!
Any recommendations on what to replace the cover with? OEM or aftermarket?
3) Since I have the cover off, I want to check my clutch basket. Do I just unbolt the 6 bolts that are visible with the cover off and slid it out?
Thanks!
Wow I can't believe I forgot to mention I'm on a 2008 300XC-W.
I think I figured out the price difference. They're both the same cover, except the 2008 has the black color and the 2011 is just the clear metal.
