yz ttr 125
Alright, sorry but the TTR section is dead. Got a 2006 TTR 125 LE that starts just fine, idles just fine takes off just fine. As soon as its hot when you let off the gas it dies and wont restart. Then it will restart after a minute or two but if you touch the gas dies right away.
I have cleaned the carb properly multiple times, I am pretty sure it is valves at this point. On my way home to play with it, how do I properly find TDC on these bikes so I can check valve clearence? Also, would valve clearence effect how it dies if you touch the gas after its hot or is the needle in need of some adjusting? I thought I read 2006 & New ttr do not have adjustable needles.
Got it figured it out, it was that white plastic washer that sits with the main jet. Main Jet Washer? Had it sitting above it on the nozzle. Finally fixed!
