needle clip position question
2008 DRZsm
3X3 mod, and I think the previous owner did something to the stock muffler to make it sound louder. do the stock mufflers usually have a spark arrestor? mine doesnt.
anyways, heres the problem
very close to half throttle the bike will stumble. If i try to accelerate by using half throttle it wont really go, i have to give it a tad bit more than half throttle, and then it will really pick up. It feels like what happens when you are just starting to run out of gas, and it starts sputtering a bit. It runs very strong at any other throttle position, which makes me think it has something to do with my needle position.
Its jetting 25 pilot, 155 main. im at 1000ft. im not sure of the current needle position. Do you think i need to go richer or leaner on needle setting?
thanks for any advice. 👍
Yep, they have spark arrestors from the factory.
I'm in Missouri too, 1000ft. Here's what I'm running:
155 main jet
Blue needle
4th clip position
Factory pilot jet
2.75 turns out on the fuel screw
3x3, extended fuel screw, and factory exhaust. Settings are perfect for me.
WGW
i guess ill pull the carb when i get time and take a look at the current needle and position.
155 main jet
Blue needle
A 155 main jet sounds a little lean for a JD blue needle.
