CR125 No powerband and smokes alot
I bought a 1999 Honda CR125 that runs and I can rev like crazy when sitting still but when i start moving it but just bogs down and never even tries to hit any part of powerband. I thought it was compression so i put a new ring on and compression is at 135psi.
things iv done to fix it: (all honda oem parts)
New piston ring
New reed valve
cleaned the power valves
dumped old gas clean tank and put high oct. gas with proper mixture
all done with new gaskets
From research iv done im thinking maybe its the crankshaft seals... Anyone have any idea what the symtoms of bad seals would be? Thanks
Sounds like your jetting is way to rich. Take your carb off, tell us your current jetting, and go from there.
