'06 SMR510 slight flickering lights
My '06 SMR lights started flickering slightly, most noticeable at dark, all lights, indicator bulbs, turn signals, headlight, neutral indicator. Started by checking voltage and it was constant at 13.55v, checked all grds, checked electrical connectors and here is what I found.
Cleaned with contact cleaner and packed with dielectric grease, will replace with a different connector this winter. Maybe someone else will have the same problem, and get it fixed before it burns out a stator or regulator, or leaves you stranded. Mike
Edited by mike_dean
Found another wire behind headlight, the 9 pin connector. I'm not very impressed with the lack of weather packing in 90% of the connectors on this bike, being an auto mech. this is unheard of and unacceptable.
