OEM rings with Wiseco piston?
I need to change the piston (Wiseco) rings. I already have brand new OEM rings, is it OK to use or do I really need to get Wiseco rings?
Personally, I wouldn't do it. They could be slightly different and cause an issue. Unless you had a new set of both that you could measure and compare, use the Wiseco rings on the Wiseco piston. I know that some will interchange, but I couldn't tell you which ones will swap.
