leaking carb
Went to start my 2011 yz250 and as soon as I turned on the gas it started running out the tube on the bottom of the carb bowl? Whats stuck!
Same thing has happened to me and it was the needle valve in the carb. Most likely stuck.
Sounds like a stuck float valve... Sometimes you can free them up by tapping the side of th carb a little bit. If that doesn't work you should pull the carb, remove the bowl and give things a little cleaning.
