xr 100 carb problem
I purchased a 1998 xr 100, removed carb, cleaned. Finally got motor started, i cannot open the choke all the way, it will die instantly. R&R carb 3 times since and i cannot see anything wrong(rookie at carb adjusting)Any suggestions
It should die if you open the choke, unless the air temperature is below 50.
