Need help with Honda atc 200e (big red)
I have a Honda atc 200e and I'm trying to restore it I had it running the other day but now I can't get any spark I checked the spark plug and it's still good. Any help is greatly appreciated!!
The engine is brother to the 2 valve XR/XL 185/200 so here are my suggestions:
first disconnect the kill switch at the wire harness and check for spark.
Next put in a new plug; don't check for spark in bright sunlight, you won't see it.
The connection between the plug wire boot and the plug wire can become bad. twist off the boot and check the wire end. If bad cut 1/4" off and reinstall the boot.
Now we are down to components which seldom fail.
Checkall of the connections and grounds
