Piston Suggestions
My sons 2008 CRF150R has almost 40hrs on it plus the 10-15 hrs that were put on it by the prior owner so I want to replace the piston soon as he's racing it every other weekend. I was thinking of upping the compression a little bit but want to be able to continue running 93 octane. Any suggestions on brands or compression?
While it's apart I am going to put new clutch in and may even put new valves in the heads. Anything else I should replace?
Thanks
Alain
Athena Pistons
Cosworth Piston the people that do Formula 1 engines
CP = Carrillo Piston
JE Piston
Moose Racing Piston (I belive there made by CP)
Pro-X Piston
Wiseco Piston
Wossner Pistons
Vertex Pistons
There all good brands just depend how big your pocket book is that you got
Keep mind that Stock Honda Compression is 11.7:1 and it a forged pistons and the max is 13:1 that highest they go so 93 octane can got a bit tab higher something like 13.4/5:1 I belive is max.
As for Valve
Kibblewhite, Vertex or Xceldyne
There 3 Option
Stock is Steel Valve
Better then Stock Stainless Steel Valve
Titanium Valve (Very high price) if go with this besure get the matching valve spring to it and have done rigth it not cheap you need also have install beryllium copper or nickel aluminum bronze seats
Look over the Clutch Basket Finger for heavy ware
Clutch Basket
Inner Clutch Hub
Clutch Pressure Plate
If there is heavy ware you want look at get billet aluminum like Hinson or Rekluse and there other brands.
Perf Barnett Clutch Kit which include friction plates, steel drive plates and hd clutch springs I used them for min years.
Mine bike pettey much 100% bone stock other a few mods in carb and I have well over 300+ hours how ever I don't race on track but do lot hard core trial riding
Edited by shspvr
