06-08 bottom end interchangable?
Im building a motor for a friend and he needs new cases, his motor is an 06, he found a 08 bottom end complete. I checked the part # and they are different. does anyone know if i can use the 08 bottom end with 06 cylinder. also will the 06 crank work in 08 cases, same with the clutch? im pretty sure i could use the 08 bottom end and use the 06 topend as i see pistons are the same and i know the head will work, but will any of the bottom end parts from the 06 work in the 08 cases? Thanks for any info provided
The 08 has some changes but will fit. The big thing is the 08 has a sensor on the shift drum so if knows what gear it is in. Should not matter it you are using all the 06 electric. Other than that is is about the same. The head is different in the valves and the ports. but will all work.
