Yamaha 2002 blaster help
just picked up this blaster for cheap, but had a couple question.
1) the po just cut the oil injection lines and took off the oil tank and used mix fuel, but there is still about 2in of line still connected to the oil injector and was thinking of taking the pump off or just plug the lines so that water and dirt dont get sucked through?
2) when i cleaned the carb, i noticed that the needle that holds the floats was pressed in or? did not seen to want to move, one side had a bigger diameter and only seem to come out one way but not sure? is there a idle screw? a see a hole with threads, its not air screw or choke.
Im most likely sure that im gonna need to jet the bike but will see how it runs this weekend. Thanks for the help
Edited by crider400
