KYB Shock - How to release nitrogen?
I have a 2012 KX450F (KYB suspension). I am going to change the shock oil but don't know how to release the nitrogen from the bladder? :thumbsup: Do I need a special needle valve or something?
I've only ever worked on shocks that have a schrader valve on the bottom of the bladder.
Never mind. It took a few hours of looking but I found the answer.
By the way, we have a replacement cap that has a valve built into it. The valve is recessed. We also use these on the YZs and WRs to keep the heat from the exhaust away from the shock.
$38
Fits:
09-12 KX450F
06-09 YZ450F
06-12 YZ125/250/250F
07-11 WR250F/450F
There is a small hole in the center of the cap.
You have to insert a needle to let the pressure of and refill it after servicing.
Is it like the WP needle for KTM's?
Or a special KYB tool, because I have never seen this before (only worked on CRF showa)
Should I rather buy an aftermarket bladder cap with a schrader valve?
Thanks!
yes like the setup ktms use on the forks
Even if you buy the new cap you will need to release the pressure. You can use a hypo needle to release (not fill) pressure if you don't have a proper one.
