Bleeding Clutch
How to Bleed the clutch on my 2003 200SX. Put straight mineral oil in it but it seems stiff.Any help would be great.
Did you bleed the clutch from the bottom? make sure there is no air in the line..... I would take the clutch cylinder off and inspect the 'O' ring as well as the inside of the cylinder incase there is marking from the piston on the inside of the cylinder. See how you go? feed back.
Any time my clutch was hard to pull (harder than normal) it had air trapped at the banjo bolt. I use 2.5 wt fork oil (use what you want) and a 35 cc syringe to push the oil back wards from the bleeding port back to the M/C. Once the oil starts running over just keep on until you don't see any more air come through the M/C. A few times I had to crack the banjo bolt while pushing the oil through to get all of the air out.... I'll use the hole 35 cc just to hep flush the old oil out...
