Will any other year cr125 head fit on a 91
What's up I have a 91 cr125 and the head is trashed and I can't get it to seal. Will any other years fit on the 91 other then 90? Thanks
1st id get a decent size pane of glass and some rubbing compound, add the compound to the glass and work the head and cylinder surfaces like this
then do the same on the cylinder with the studs removed, iv done this hundreds of times and works great ,a good cheap fix, always use a new head gasket also
if your to lazy just look at the gasket sets available and see which years they cover eg
http://www.ebay.co.uk/itm/Honda-CR-125-CR125-1991-1992-1993-Top-End-Gasket-Set-/200644784141?pt=Motorcycles_Parts_Accessories&hash=item2eb75c700d#ht_1087wt_698
and that will give you an idea which is the same and it looks like alot of years are the same
hope this helps
norfe uk
