75 KX250 Spokes
I am looking for a source for spokes and nipples for 1975 KX250.
Bike is to be all original. No Buchanan.
I tried a few of the online Kaw dealers but it appears they are all tied
together.
I am also confused on the spoke part numbers. There are several numbers. Some with 18 spoke groups but then there are ones with 9 spoke group. Do not understand.
Any help would be appreciate.
If someone has a nice used set, I'll buy them. I need front and rear.
Rob
It looks like there were different hubs depending on the model. Some of the hubs had a different diameter on the left side spoke mounts than on the right. This causes you to purchase 9 inner and 9 outer for the left and then a shorter set of 9 inner and 9 outer for the right. Other hubs had the same diameter and simplify your order to 18 inner and 18 outer. You should measure your hubs and see which you have.
Here is a site which says they're all still available.
