Help to determine shock piston
Just bought some second hand KYB A-kit suspension for my kids YZ85
complete forks with trees and 2 shocks
The shock that came of the bike used for training wasnt working proberly and what i found was that the piston was worn out in the area where the sims seals the ports (is this normal???
My question is if anyone recognize this piston so i can order a new one
the suspension was maintained at a mx-tech dealer if that helps
piston diameter is same as stock
On the pictures i allready machined the piston ,but im not sure if it will hold up
Thanks
Kim
Thanks
Kim
Usually it's not the piston face that fails, but more the piston band or o-ring behind the band. I am not saying that the face of the piston does not need surfaced from time to time assuring a good seal.( yes there are pistons with a small degree of slope to allow a certain amount of shim pre-load) If it is surface to ensure a proper seal of the shims it will be ok.
I see what you meen and its possible that its part of the problem (but still i need a partnr for pistonband etc)
But the packing surface was deff. damaged ,it was easy to see as the anodizing was worn away in the area where the sims is opening
i had to machine aprox 0,1mm away to get it strait, afterwards i polished the surface on a glasplate
Thanks
Kim
Thanks
Kim
I would check a Mx-tech affiliate, and see if that is their piston. I haven't seen any of their latest designs, but it looks like it might be theirs.
thanks
i was kind of hoping that someone could say ,hey thats a :::: piston:smirk:
and make things a bit easyer for me
i will see what i can find
Kim
That looks like a Mx-tech piston to me. I have one layin around and it looks just like it.
Thanks
Ill give them a call
Kim
